Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
이 답변이 도움이 되었나요?
thanks for answering
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 495
댓글 5개
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
mayer 의
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
Amr Ateef 의
If its pure, then you should use it. My answer is YES!
Kon Dev 의
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
John Potter 의
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
Amr Ateef 의
