주요 콘텐츠로 건너뛰기
The Honda Fit, also marketed as the Honda Jazz, is a five-door, front-engine, front-wheel drive B-segment subcompact car manufactured and marketed by Honda since 2001 and now in its third generation. Marketed worldwide and manufactured at ten plants in eight countries, sales reached almost 5 million by mid-2013.
Location of ECT Sensor 1 on top of motor
I can not find the ect location on top or side of motor. Already change ect 2 on radiator just need to figure out where #1 is located
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
How can I remove ECT 2..?
댓글 달기
답변 1개
선택된 해법
@mgd1216 ECT 1 is under the air cleaner assembly. You need to remove the air cleaner to get to it.
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
can you sell me where the crankshaft sensor is? i see its on the diagram but is it front back or rear of the engine ?
@robertjohn11533 it is on the front of the engine
how do you remove the air cleaner to get to ECT 1
You need to unscrew the two screws holding the filter housing. Unscrew the clamp between the top of the housing and the throttle and remove the clamp that also connects another accessory to the filter housing.
In Polish:
Trzeba odkręcić dwie śruby trzymające obudowę filtra. Odkręcić obejmę pomiędzy górą obudowy, a przepustnicą oraz zdjąć obejmę zaciskową która również łączy inne akcesorium z obudową filtra.
댓글 달기
답변을 추가하세요
Mitchell Dye 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 45
지난 30일: 262
전체 시간: 12,935
