주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
서드파티 및 Microsoft Xbox, Xbox 360, Xbox One, 그리고 Series X|S 공식 컨트롤러에 대한 수리 정보 및 분해 안내서입니다.
Xbox One controller A button won't work
Hello iFixit fellas.
I'm reaching you because i have an issue with One of my Xbox One Controller.
A button won't work.
Things i've done :
Teared the entire controller apart.
Cleaned the rubberised contact pad, making sure not to scrub to hard underneeth to avoid removing the graphite coating (which makes contact with the PCB.) With Q-tips and isopropyl alcool.
Cleaned up the PCB lightly scrubing with a toothbrush and alcool.
Reassemble the pad -> Nothing. Every button worked exept A.
Teared down again, removed the A plasitic button + rubberised pad, reassemble the controller again. Leaving an hole where A is on the PCB.
I tried to make contact on A with a Q-tip + aluminium foil. Nothing.
I teared the Controller apart a third Time and then i discovered this
이미지
So, maybe the traces are broken even tho i don't think they are connected or even, corresponds to the A button.
Here's the area behind A (SW11)
이미지
Do you guys know the test points for the A button ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
If your Xbox One Wireless Controller has sticky or broken buttons, see the Xbox One Wireless Controller Has Sticky or Broken Buttons problem page for possible problems and solutions.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My Xbox controller's "a" button is pushed in way more than the rest and won't raise up, and is very sensitive to touches, can I get help? I really need it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Thomas Dangest 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 40
전체 시간: 1,178
