주요 콘텐츠로 건너뛰기
Repair and disassembly guides for GE Microwave ovens.
349 질문 전체 보기
Door Will Not Open
Depressing the Button does not open the door. I can depress the button and use a very light “prying” with a knife and the door open fine - and keeps opening if I do it in successive attempts. However, after a few minutes, it again will not open.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Peter Kloeber  sounds like your MW has an issue with the interlock switch. Since you did not tell us teh model here is some genreal information for GE MW to check.
DOOR SENSING AND PRIMARY INTERLOCK SWITCHES
The primary interlock switch is mounted to the plastic switch bracket on the bottom, the monitor is in the middle and the door sensing switch is mounted to the upper portion of the plastic switch bracket. The power relay is mounted on the smart board. They are activated by the latch heads on the door. When the door is opened, the switches interrupt the circuit to all components, except the oven lamp. A cook cycle cannot take place until the door is firmly closed thereby activating both interlock switches. The primary interlock system consists of the door sensing switch, primary interlock switch and power relay.
MONITOR SWITCH
The monitor switch is operated (the contacts opened)indirectly by the bottom latch pawl. The pawl operates a cam switch, which in turn, actuates the monitor switch. The switch is intended to render the oven inoperative by means of blowing the monitor fuse when the contacts of the primary interlock switch and power relay fail to open when the door is opened.
Functions:
I . When the door is opened, the monitor switch contact closes (to the ON condition). At this time the primary interlock switch and power relay are in the OFF condition (contacts open).
2. As the door goes to a closed position, the monitor switch contacts are first opened and then the door sensing switch and the primary interlock switch contacts close. (On opening the door, each of these switches operate inversely.)
3. If the door is opened, and the primary interlock switch and power relay contacts fail to open, the monitor fuse blows simultaneously with closing of the monitor switch contacts.
CAUTION: Before replacing a blown monitor fuse, test the primary interlock switch, door sensing switch, monitor switch and power relay contacts for proper operation.
Primary Interlock Switch Test
Isolate the switch and connect the ohmmeter to the common (COM.) and normally open (NO) terminal of the switch. The meter should indicate an open circuit with the door open and a closed circuit with the door closed. If improper operation is indicated, replace the primary interlock switch.
Please be aware that a microwave carries voltages high enough to kill you. If you have never worked on one or are unsure of working on it, contact a professional to check it for you.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Peter Kloeber 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 71
