주요 콘텐츠로 건너뛰기
The HP Compaq 2510p, model number "GM651AW" and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 질문 전체 보기
My laptop won’t charge.
My laptop won’t charge and displays a steady white light and a blinking yellow light on the charging led. Whenever I take out the battery it still won’t turn on. I even tried replacing my charger although I don’t know if the one I replaced it with is compatible with it although there the same brand. I need help on fixing this cause it’s not even my laptop but my sisters laptop and I have not told her it isn’t working as yet.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@romainedwyer check your AC adapter with a multimeter to make sure that you have the right voltage. The brand is irrelevant for as long as the specs are the same. For this laptop you will need a 65Watt 18.5V 3.5A power adapter. Let us know what you have.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Romaine dwyer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 4
전체 시간: 181
