Metallic connectors inside key fob not attached to silicone button pad
My metallic connectors inside key fob not attached to silicone button pad & have become detached - so the whole fob is no longer working. What is the best adhesive to try and re-attach the metal connectors to inhibit them from wondering around causing a mess?
좋은 질문 입니까?
댓글 5개
Can yo post some pics so we can see what you are facing here 기존 질문에 이미지 추가하기
Dan 의
You appear to be missing some of the pads! Correction: I count five here two is still in the key and three on the table. You need seven!
Dan 의
The key fob only shows 5 buttons on the front. There are 3 on the table and 2 of them still in the key fob. They look pretty dirty and need cleaned to make a good connection with the board.
Joshua Freeman 의
All these comments are good, but I had the same problem with my key fob. When the discs become dislodged that particular button will not work. Mr personally,I used Super glue, just a touch...
Ray Sanders 의
I used contact cement
Paulm 의
