주요 콘텐츠로 건너뛰기
가정 또는 사무실에서 사용하는 이동식 가구 수리.
38 질문 전체 보기
How do I replace a wooden chair leg?
I bought a used kitchen chair that’s missing a leg. The original owner no longer had the chair leg. Does anyone have advice for how best to buy and install a chair leg to the appropriate length? The original chair legs are at a slight slant. Pictures of the chair included below!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
chair legs are usually made on a lathe. otherwise, need a saw, a drill with the right size drill bit, a hand planer, some type of sander, some wood glue and some clamps, along with measuring tape and marker. of course you’ll also need to use safety glasses, and maybe some hearing protection and work gloves, too.
consider carefully removing other back leg (that’s still currently on the chair) and using it to plan making a copy for the other leg. don’t know if you can actually find someone who sells a variety of legs for chairs, but you’ll need to get a piece of wood close to the same diameter of, and a little longer than your other chair leg. since it’s painted, the type of wood isn’t so critical. Oak is stronger than pine, but harder to work with and more expensive.
clamp the wood to a table top and drill the right size hole, the right depth, at the right location along the length of the wood, and at the correct angle. use the hand planer to shape the leg to match the profile of the others, adjusting the piece and resetting the clamp as required. use the sander to make the new leg relatively smooth. copy the angle at the top of the other leg and mark a line to cut that angle on your new leg, and use the saw to cut the end of the leg off at the right angle. then mark the other end to the right length and cut it off.
apply some wood glue to the end of the legs that go into the bottom of the chair seat, and in the holes where the lower rails fit into the legs, place the legs in position at the seat and fit the rails into place and allow the glue to set.
this is much easier to explain than is is to actually do. if you’re not experienced or fitted to do woodwork, you may want to just take the chair to someone who does woodwork, and they might help you out.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thanks for the information.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I used to have a table that was missing some parts when I bought it, and I discovered it only when I got home. So, instead of spending a lot of money purchasing a new one, I ordered those parts online. That's what I am recommending you do as well. You can check over here, and maybe you can find the missing piece there. There are plenty of shops that are also providing parts of the furniture for cases like yours. You should specify what material it should be made of and the color in order to find the suitable one for your chair. If you are lucky enough, you might find one at a low price and good quality.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Replacing a wooden chair leg can be a relatively simple task, depending on the type of chair and the extent of the damage. Here are some general steps that you can follow to replace a wooden chair leg:
  1. Identify the type and size of the chair leg that needs to be replaced. Measure its length, width, and thickness, and note any particular design features or decorative elements that you may need to replicate or match.
  2. Remove the damaged leg from the chair by unscrewing or unsnapping it from the seat or base. Use a screwdriver or a wrench to loosen any screws or bolts that hold the leg in place, and gently wiggle the leg until it comes off.
  3. Clean the area where the leg was attached by removing any debris, glue, or finish that may interfere with the new leg's installation. Sand the surface lightly if necessary to create a smooth and even contact.
  4. Choose a replacement leg that matches the original leg as closely as possible in terms of material, color, shape, and size. You can buy pre-made legs from hardware or furniture stores, or you can make your own leg by cutting and shaping a wooden dowel or a piece of lumber to fit the chair's specifications.
If you're struggling with all these steps you can always consult with wood engineers from here for example https://bcfloors.ca/hardwood-flooring/en... they are real professionals and can support you. Based on your photos I am not even sure it's 100% wood, might me MDF.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Amanda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 18
30일 전: 49
전체 시간: 759
