주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
Replaced display - Home button has TouchID but does not work as Home?
I just did a screen replacement with an iPhone 8. Moved the Home button from old to new with no issues. I have come up with a weird issue.
After boot-up, after about 10 seconds, an on-screen home button shows up. There is no error that comes up in relation to the home button (Touch ID can not be Activated, for example.)
You can not use the Home button to turn on the device or go home. However, Touch ID still works. Can register new fingerprints. It recognizes registered vs unregistered. But it does not work as an actual Home button.
Things Tried:
  • Reboot phone fully (Vol Up - Vol Down - Power)
  • Reseated connector for Home button
  • Reseated connector onto main board
  • Inspected all connectors (All fine)
  • Cleaned connectors
  • Tried another screen in case cable on new screen caused it
  • Cleaned around edges of home button and opening
  • Ensured nothing binding on new screen opening
  • Confirmed all correct screw lengths and positions (All fine)
  • Ensures support bar was straight
I’m at a loss right now. Any suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
It sounds like the turtle ic (U10) on the home button assembly has been damaged. They are pretty fragile. Check under a microscope or magnifying glass.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I did check it. Does not appear to be cracked or the edge lifted at all. I will review it further. Is there any solution if that is damaged besides an Apple store?
I can not see any issues. I don't have a camera set up to show for that small however. I can't see anything else obvious.
Well its useless now anyway so u might as well give it a go try not to do any further harm so do the following at ur own risk do it gently and only do it once... turn the flex upside down on ur desk so the turtle is face down and gently massage the back of the flex with a soldering iron, just for 10 seconds then try it
Failing that there are companies that provide microsoldering services and its possible to replace the ic
댓글 달기
I would try another screen and see if the same condition occurs to eliminate the possibility of screen, which may not be perfect match.
I would also put the old screen back and see if that behavior repeats.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Good point forgot that as the most obvious first thing to try :)
Indicated in original post that I had tried another screen. Since my last update, I did put on the original screen, and it works. I tried a third screen. Didn't work. Tried a known good but damaged screen. Didn't work. The company doing funny stuff I'm wondering now.
The fact that original screen works, eliminates the problem with the home button. It points to the quality of your screens, or the fact that the screens you have, do not exactly match the model of this specific device. The refurbished screens are taken from the old devices and fixed up with additional layers and connectors and if devices they came from are different models, it maybe slightly tighter or looser, which may cause ghost typing, touch id problem etc...
댓글 달기
Hi, just try to reset the connection between your home button and lcd or else if that still dont work maybe your lcd has faulty issue
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Andrew Klein 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 127
