Lenovo IdeaPad 11s: What size torque screwdriver is required?
Looking at the tutorials, it states you only need a Philips #0 but you need a torque screwdriver but I don't know what size is required? Lenovo IdeaPad 11s
좋은 질문 입니까?
좋은 질문 입니까?
From some research it looks like it might be a Torx 5. A lot of electronics are T3-T6 I’ve noticed, with the exception of some. Try the T5 though!
해당 답변은 도움이 되었습니까?
Hi,
Torque screwdrivers are used to prevent under tightening of the screw causing it to not hold correctly or over tightening of the screw which may damage the thread or head of the screw.
Looking online torque screwdrivers are not cheap and are usually used by professional repairers as their frequent use justifies the cost of the screwdriver.
If you are doing a one-off repair, it may be just as well to use the appropriate sized screwdriver and simply slug the screws up tight, without overtightening them or damaging the screwhead
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 16
30일 전: 57
전체 시간: 2,225
