주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair and disassembly guides for Garmin GPS devices.
Replacing the digitizer glass
I just purchased a replacement glass for my Garmin Edge 800, but it is just the glass and not the glass in the frame. How do I remove the cracked glass from the frame and install the new one? The original appears to be glued to the frame
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
@dwiener
use a good hair dryer or a heat gun on its lowest settings. Move the hot air along the sides of the digitizer to soften the glue. Once soft, use a thin tool to replace the digitizer.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I’m trying a hair dryer. The case is getting hot, but the glue doesn’t appear to be softening. About how long should it take?
@dwiener big depends on the glue they are using. It is most likely a adhesive strip. Try a guitar pick and loosen it when the heat is relatively high without melting the case.
댓글 달기
답변을 추가하세요
Dennis Wiener 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 479
