I have no picture but I do have audio
Visio E701i-A3
Hello how are you guys I need help I'm having the same problem I have no picture but I do have audio it's the same TV as Brent i did changed the T con but I still dont have picture at all so I'm wondering how can I test the power voltage but what could I be I don't know if you guys can show me.with picture how to measure the voltage on the power board
Update (06/23/2019)
Here is a picture
Update (06/23/2019)
You mean this two ?????
Update (06/23/2019)
I tested the power voltage here is the pic I'm getting 3.38 here I will add the picture
Update (06/23/2019)
Here is another pic I unplugged the power supply from the wall and I dont get stand by voltage is that normal here is a picture
Update (06/29/2019)
Hello how are you @oldturkey03 so here I have some pictures of the boards
좋은 질문 입니까?
댓글 12개
Ok today I will take some nice pictures of all the boards thank you so much @oldturkey03 I really appreciate the help thanks so with the pictures you will be able to pointed out were should I resoldering????
victor galeana 의
Check the bottom of the boards where the connectors are soldered to. Sometimes a simple resoldering of those contacts can help.
oldturkey03 의
as well as the one to the right of those and the one below that
oldturkey03 의
You think it could be the power supply board or not at all ???
victor galeana 의
It's a Vizio so anything is possible. Personally, I think it is less likely and I would check the voltage from power board to main board. I am leaning toward the main board or the panel (hope not)
oldturkey03 의
댓글 7개 더보기
