Noticed it restarts showing some message: the computer had to restart
Hey there,
I just updated a MBP 13" mid 2012, I changed the RAM for 2x8Gb 1600Mhz DDR3, and a SSD 1Tb as a main disk and using a caddy I set up the 500Gb HDD instead of the super drive.
Installed MacOS Sierra everything seams to be just fine but in tree days of use I have noticed it restarts showing some message: the computer had to restart …
Do you Guys have any clue about what the problem could be? any help? thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@alberte22 After it restarts, immediately go to terminal and type in this command:
log show --predicate 'eventMessage contains "Previous shutdown cause"' --last 24h
Then post in here what the last shutdown code number is. The code should be something like, -2, 0, 3, 5, etc.
댓글 달기
