주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kohler는 가정용 및 전문가용 승용 제초기와 정원용 트랙터에 사용되는 가솔린 엔진을 제조합니다.
Why is my mower not wanting to engage the blades right?
2013 cub cadet 1050. When I engage the mower deck it wants to sputter to a stop. If I mess with the throttle a little it will come on and mow perfectly. Sometimes it just does its little sputtering fit and will engage. New belt, spindles, blades, and fuel filter.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@stevenstickley make sure that you replace/clean the air filter and the spark plugs. A plugged air filter or faulty plugs can cause the engine to run rich. after you check on that I would recommend checking the choke/carburetor. If the mower still bogs down after that, the problems is most likely a carburetor. A good cleaning of the jets and float (needle valve) and setting the choke should work.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
It runs perfect when the decks off and after the mower finally engages, that's what threw me off a little
It sounds like it is choking when you put a load on the engine which is commonly caused by a carb that is running to rich.
댓글 달기
답변을 추가하세요
Steven stickley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 35
전체 시간: 455
