play for some second, then write fan-ng and then stop.
When I plugs my Samsung ,it will play for some second, then write fan-ng and then stop. want can cause it
좋은 질문 입니까?
좋은 질문 입니까?
Hi @ afriday96,
What is the model number of your Samsung DVD player?
fan-ng most probably means "fan no good",
First check that the fan’s air vent is not blocked or obstructed by dust.
If it is clear check that the fan is working (assuming your player has a fan-you don't state the model number).
If it isn't working, check with an Ohmmeter that the fan motor is OK. Do this with the power disconnected from the unit and the fan disconnected from the motherboard.
If the fan motor is OK then you’ll have to check if there is power being applied to the fan motor when the unit is powered on.
해당 답변은 도움이 되었습니까?
Thank you so much is working now
Thank you so much 😘😘❤️❤️. Is working now
I am having the same problem. I have blown dust away. But still not working. I can't take the lid off my samsung blu ray. Took 2 screws out of back, but still firmly shut
What is the model number of the BluRay player?
24 시간 전: 3
7일 전: 20
30일 전: 122
전체 시간: 10,282
댓글 2개
My fan blows normal but still getting the message
Dean Raubach 의
@Dean Raubach
What is the model number of the player?
A lot of fans have a sensor in them that lets the control board know that they're operating.
If you check the fan connector if it has more than two wires it will have a sensor (usually a hall effect sensor which indicates speed but it could also be another type).
Perhaps the sensor is faulty or the wiring back to the control board
jayeff 의
