주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Sony DVD players.
65 질문 전체 보기
Why does my DVD player only play 2 DVDs out of 20?
I have a 2002 Sony 5 Disc DVD/CD Player (DVP-NC615). It has a Precision Drive 2 System.
*Notes.
I have already taken it apart and cleaned it.
I do not have the remote.
Hasnt been used for a few years.
I have tried to play approximately 20 DVDs on it and only 2 will work.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Typically this type of behavior is indicative of a failing laser. Try playing a number of standard CDs. If these all work without fail, it suggests that the laser is starting to weaken. If you have already cleaned the lens, then the “simple” fixes have already been applied. At this point, changing the optics assembly is the next step.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I would like to note that I think it has to do with the fact that both the DVDs that work have a small "rise" in them. You know when you flip over a DVD and there is a ridge ? Both of these DVDs that work are double sided and play on the side that has that ridge up
Hi @missfixit90 ,
Did all the discs work before in the unit?
If not, here's a link to the user manual for the player.
Scroll to p.7 and p.8 to find information regarding which discs are compatible with the player
댓글 달기
귀하의 답변을 추가하세요
Jess Stevens 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 119
