주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
battery shuts down on start up
on startup thru the bar gain at 3/4 the mac shuts down did a PRAM reset three chimes still having the issue battery works if start up is n cable and then removed too battery but will not start on just battery power
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
With this little info you supply you’re looking for a wiz more than a tech, however if it’s a 2011 i7 quadcore it’s probably another dead GPU.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I’m assuming it’s a Macbook of some kind since you mention it’s got a battery… year and model would be helpful. Other than that, I think you said your MacBook has a couple of problems:
  1. Makes 3 beeping sounds when you start it
  2. Does not fully start up and shuts down when the progress bar is around 75%, even after a PRAM reset
  3. Only starts with power adapter plugged in, but will run on battery alone after it has started
For #1 - either bad or loose RAM. Try reseating or replacing it. I would unplug the battery before doing this.
For #2 - could be a bad drive or OSX errors - what version are you running? If you have a newer version, get into recovery mode (hold Command + R keys after starting) and try Disk Utility to fix any errors. For older OSX, you’ll need a bootable OSX on CD or USB.
For #3 - you might have a bad battery - common if it’s more than 5 years old.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How about reading the question before throwing random answers ?
댓글 달기
귀하의 답변을 추가하세요
RANDALL NICHOLAS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 34
