주요 콘텐츠로 건너뛰기
Repair and disassembly guides for the Huawei Honor smartphone line.
309 질문 전체 보기
Camera got blurry because I dipped it in water.
My phone is Honor 10 but it was not in the selection.
I watched a video that the phone is water resistant so i just dipped it in swimming pool (just the camera) and recorded a video for 4-5 seconds.
After 5 mins the camera stopped working.Then after an hour there was fog in the camera. I put my phone in rice for a week so the camera and the phone started working good. Then after a week the camera got blurry(like it is out of focus). I tapped it 2-3 times and it started working properly.
Then this started happening more often and i used to tap it and it used to start working.
But now it's been 3-4 months and it's gone blurry and doesn't work even if I tap it but sometimes randomly starts working.
What would you suggest i should do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
AlpHa 69  sounds like it did get moisture in the camera. This may now have lead to corrosion. BTW Rice does not do anything for internal moisture unless you would have disassembled your phone. Even then, that is doubtful. Anyhow. Consider changing the camera and checking the rest of the internals for further liquid damage. Check on here for a teardown or this video to get you into the phone.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
AlpHa 69 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 17
전체 시간: 1,053
