주요 콘텐츠로 건너뛰기
{A1706 / EMC3214}—2018년 7월 출시, 이 MacBook Pro 13”는 쿼드-코어 i5 및 i7 프로세서 그리고 Intel Iris Plus 통합 그래픽 포함.
199 질문 전체 보기
MLB 820-00850 does NOT match boardview/schematic... any ideas?
i took in a 2018 mbp13 A1989 after a liquid damage and a serious moron opened it up.
several pieces are missing from the MLB, but one cannot be identified as it exists on the board (and the teardown photos) but NOT in the boardview or schematics. has anybody worked on this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
@reverendalc preliminarily it appears to be a 74AUP1T97GM IC Gate. Check the datasheetLow-power configurable gate with voltage-level translator and you may confirm by measureing on the solder pads. Check with Digikey.com or Mouser and see if they have the right package. The part itself is less than $1.00USD
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Awesome thanks I’ll look into that ASAP
댓글 달기
You'll need to locate a more upto date schematic and board view. The one you have is clearly incomplete. The newer models have been harder to get and I've only found early drafts which are incomplete.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes it’s clear that this boardview is incomplete. I was hoping somebody may have this board to look at for me...
댓글 달기
귀하의 답변을 추가하세요
Ronnoc Nailli 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 21
전체 시간: 1,777
