주요 콘텐츠로 건너뛰기
The Canon EOS Rebel T3i, released in March 2011, can be identified by its SKU (SKU:5169BO32). Also known as the EOS 600D and the EOS Kiss X5, this camera is a Canon Digital SLR with 18 megapixels.
Error code 20 appears when I turn on rebel t3i
Is there a way to repair error code 20?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@cuitm this is a general error code which indicates a mechanical malfunction in the camera, so not very specific.  Luckily this camera only has a few mechanical components so you do want to check your reflex mirror and the focal shutter. Most commonly this is actually caused by a mechanical issue with the lens. Try another lens and see if that resolves the issue. If you do not have access to another lens, remove the current one and take a picture without the lens (you will of course not get a picture;-). If you can verify that the error code no longer shows, you know that you have a bad lens.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
LaLioni Tucker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 1,211
