주요 콘텐츠로 건너뛰기
The second generation was introduced as a 2003 model at the 2002 Chicago Auto Show, based on the new Impreza platform, featuring several fine-tune improvements over the past model.
Why is the engine knocking after overheating
I ran the car out of oil almost completely and it overheated it's never overheated before it's been over a hundred thousand miles on it and now the engine knocks when we turn it on and I just put new oil in it. What do you think the NACA Muse
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Matthew Hyatt  This “I ran the car out of oil almost completely and it overheated” could be indicative of some major engine damage. From main bearings, to piston/rod damage and camshaft/ lifter/valve damage. I suggest that you have a mechanic at least do an inspection since it is a bit too much to go over. There are just to many variables with this.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you. For the record it was actually my girlfriend after I told her to put oil in it and ran it out of oil and overheated when I showed up it was knocking and had her to shut it off this is exactly what I told her that your answer confirmed it thank you very much
댓글 달기
답변을 추가하세요
Matthew Hyatt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 20
전체 시간: 1,417
