주요 콘텐츠로 건너뛰기
Televisions made by the Chinese multinational electronics company, TCL.
264 질문 전체 보기
How to Flip or Invert the image on a TCL 50"
i am trying to make a video wall with 6 TV TLC , but i Need to flip or invert the image on some of them so i could put it on their own spot. The six tv’s going to show up the same image but still i would like to flip another tv so it could be on vertical mode.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@samuelmgm12
you did not tell us what model this TCL is. Things like that are only possible if the soft/firmware supports that in it’s system. The only other way is by modifying the T-con board but there is only limited information for TCL branded TV’s. I suggest you check through the menu of this model and see if you can find what you are looking for.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Oh ok, Thats why i havn't bought it yet, because I need to be very sure to recommend the church to buy the units after check if the flip or invert image are supported by the brand
댓글 달기
062598 menu 001 to 999
Dial this code
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Samuel Mauricio Garcia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 13
30일 전: 55
전체 시간: 3,889
