주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
iPhone 8 bad lightning connector?
so i recently replaced my display/screen couple weeks ago. upon opening it, i noticed the water indicators were red. after a couple weeks of a good screen, my phone randomly turned off. i opened the phone and was reconnecting all connectors but it only powers on without the lightning connector plugged in. could i had a damaged connector or could it be more than that?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It may be that if water was just a very little amount it took some time to show its effects. Lightning assembly is quite well sealed and components are well protected on it, but still..water almost like air, gets easily anywhere once it finds its way in. You will have to go through an accurate inspection, get yourself a magnifier and a good light source. Usually it’s not that difficult to see traces of dried liquids. Disconnect battery and check carefully all connectors for signs of oxide, it usually shows with a darkened spot.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I replaced the connector and works perfectly!= now!
댓글 달기
귀하의 답변을 추가하세요
Jesse Garcia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 88
