주요 콘텐츠로 건너뛰기
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 질문 전체 보기
Replace Screen OR Logic Board if images are burned into screen?
So I’ve adjusted the “Accessibility Features” for the discoloration and the burn in. It took care of the color issues, but I still have old images burned in on the screen. We use this for work, and it will be on the same screen the majority of the time that the screen is on.
Should I replace the LCD and digitizer? Or is this a Logic Board replacement? Or something else?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Couldn't tell you unless I had the iPad in front of me and tried another screen myself. To save the trouble of buying another screen with the risk of it having the same thing take it to a reputable repair store to get it fixed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It sounds like a bad lcd to me. iPads are usually pretty resilient to burn in. But as Ben said,taking it somewhere to be repaired would be wise. Then if they replace the screen and it doesn’t work you can possibly get a refund.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
travisabraham 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 119
