주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Lifted pad for charging IC
So as I was trying to remove some solder from the pads (rather unsuccessfully), I have lifted a single pad, revealing the copper underneath. How screwed am I?
https://gyazo.com/48a182018b8951d687cf1b...
b3 is the pad
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
That depends on which pad is lifted. If you have a connection point nearby, you could run a jumper. If it goes within inner layers to the CPU, then yeah, you are probably in trouble.
Use a tool like Phoneboard to understand what connects to what and post more and better details so we can help you.
해당 답변은 도움이 되었습니까?
점수 4
댓글 11개:
Sorry for not adding this to the post originally. b3 is the lifted pad.
That looks straightforward enough, jst run a jumper from the coil and then create a a new B3 pad with the other end of the jumper wire.
@refectio Just to make sure, this is what you mean right?
https://gyazo.com/cdc0546952da320aa9c799...
I've had someone tell me I can just put copper over the exposed copper on B3, and that would be enough. He is wrong, right?
You have asked several questions in the last month and not once have you voted on an answer, despite getting quality contributions from several experienced techs.
Is it that hard to upvote an answer? After all, people are taking time out of their hectic schedules to answer your questions and help you out.
Voting is not just instant gratification. It reflects the value of an answer and over time, your question may garner a whole bunch of "answers", some of them better than others. Voting (and selecting a solution when appropriate) allows the better answers to filter to the top to the benefit of the entire community. That is the mission and purpose of this forum.
@refectio Too bad I can't upvote a comment, this last one would really deserve it :) That's the reason why I usually ignore "techs" questions, somewhat regular requests of help that involve others doing the troubleshooting on their behalf without too often any kind of even a symbolic sign of gratitude, leaving aside the contribution one should give back to help others in the repair community. More and more I understand the pay for help requests approach other Pro forums have implemented.
댓글 6개 더보기
댓글 달기
귀하의 답변을 추가하세요
Ben Parkinson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 45
