How to fix the error 9?
the iTunes can not restore the ios because the error 9
좋은 질문입니까?
Have you jail broken it or attempted to?
Error 9 generally occurs during a firmware upgrade, and has something to do with a problem with the USB connection to your device that is causing it to unexpectedly disconnect when syncing.
It can be a hardware problem e.g. if the dock/lightning flex is water damaged or something.
Do all the basic stuff first:
You need to provide more specific and background info if you need more help.
이 답변이 도움이 되었나요?
no jail broken
do not attempted to do that
Hi
Uninstall iTunes and reinstall from Apple direct website https://www.apple.com/uk/itunes/download... and step 2 use a different lighting cable .
And it should fix it and if it doesn't work it's a problem with your device
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 177
