Samsung Television will not power on
Model Code: PN42C430A1DXZC
TV will not power on. There is no backlight or picture on the screen. There is a standby light on. When I attempt to power on the TV, there are clicks coming from what I think is a relay, the light goes off for about a second, then it is back on solid.
No visibly blown capacitors or burnt components on the power supply board.
The following are the voltages taken from CN801:
1) 3.31V
2) 5.27V
3-12) 0V
When i hit the power button #1 drops to .05V, the clicks are heard then back to 3.31V
#11 goes to 15.10V, clicks then back to 0V
#12 goes to 5.24V, clicks then back to 0V
Update (08/01/2019)
T-con board fuse:
Update (08/04/2019)
Voltage reference for LED driver boards:
좋은 질문 입니까?
댓글 2개
Just to add. I thought based on those readings that it could be a power supply board, but the replacement board is doing the same thing.
Gerald 의
@oldturkey03 yes, I tried the mainboard and still the same 2 clicks and then.. nothing.
Gerald 의
