주요 콘텐츠로 건너뛰기
The Panasonic KX-TGEA20 is a phone accessory that is compatible with Panasonic devices. It features a 1.8-inch LCD display with a resolution of 103 x 65 pixels. The navigation key allows for easy and convenient use of the phone.
3 질문 전체 보기
Phone goes off after one incoming call
Phone will only ring once and then goes off
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개:
Hi,
Just clarifying.
The phone rings once and then stops ringing. Is this correct?
Is there anyone there if you answer it after the one ring or not?
Can you call out OK and if so is the line noisy?
My phone rings off after one ring no one there if they ring back it might take a few times before we can answer them We can ring them there is no noise when we do
Hi,
Have you got access to a corded phone that you can plug into the phone line instead of the Panasonic just to check if the problem is in the Panasonic phone or whether it is connected to your phone service?
댓글 달기
답변 1개
Maybe it’s a battery problem. You might want to check it if it can still supply the power needed. If not, you may consider replacing the battery?
Cheers.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sheilajohn-49@hotmail.co.uk 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 15
전체 시간: 1,096
