주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
141 질문 전체 보기
My MacBook Air hasn’t been turning on in 3 days! Please help!
On Saturday morning I woke up and my MacBook wouldn’t turn on. I’ve tried smc and pram resets already but nothing seems to be working. The only cause I could think of is that I spilled a bit of water on the touch pad but it should have dried up by now. I’ll attach a picture under the cover of it. Please help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
It doesn't take much ;-{
Tap water is not clean! It has minerals and salts which are still present on the surfaces after the water has evaporated. Bottled spring water is often heavy with minerals!
댓글 달기
답변 1개
가장 유용한 답변
Given where you spilled I suspect the Touchpad got wet and the corrosion maybe limited to it. Here’s the needed part MacBook Air 11" (Mid 2013-Early 2015) Trackpad and here’s the guide you’ll need to follow MacBook Air 11" Early 2015 Trackpad Replacement
I would start there
MacBook Air 11" (Mid 2013-Early 2015) Trackpad 이미지
상품
$109.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Aaron Quan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 76
