주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Air 11" Early 2015 Trackpad Replacement
필요한 것
    1. MacBook Air 11" Early 2015 Trackpad Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      댓글 쓰기
    2. MacBook Air 11" Early 2015 Trackpad Replacement: 2 단계, 이미지 1개 중 1개
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      댓글 쓰기
    1. MacBook Air 11" Early 2015 Trackpad Replacement, Battery Connector: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2015 Trackpad Replacement, Battery Connector: 3 단계, 이미지 2개 중 2개
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      댓글 쓰기
    1. MacBook Air 11" Early 2015 Trackpad Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      댓글 쓰기
    2. MacBook Air 11" Early 2015 Trackpad Replacement: 5 단계, 이미지 1개 중 1개
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      댓글 쓰기
    1. MacBook Air 11" Early 2015 Trackpad Replacement, Trackpad: 6 단계, 이미지 2개 중 1개 MacBook Air 11" Early 2015 Trackpad Replacement, Trackpad: 6 단계, 이미지 2개 중 2개
      • Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
      • Gently slide the ribbon cable out of the ZIF connector.
      • Adjust, but do not remove the T5 Trackpad Sensitivity Screw to change the trackpad's depth sensitivity.
      댓글 쓰기
    2. MacBook Air 11" Early 2015 Trackpad Replacement: 7 단계, 이미지 3개 중 1개 MacBook Air 11" Early 2015 Trackpad Replacement: 7 단계, 이미지 3개 중 2개 MacBook Air 11" Early 2015 Trackpad Replacement: 7 단계, 이미지 3개 중 3개
      • With one hand, push the keyboard ribbon cable in slightly to access the ZIF connector beneath it.
      • Use a spudger to flip up the retaining flap.
      • Gently slide the cable out of the connector.
      댓글 쓰기
    3. MacBook Air 11" Early 2015 Trackpad Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the six 1.5 mm Phillips #00 screws holding the trackpad in place.
      • These screws are installed tightly and strip easily. Be careful as you remove them.
      댓글 쓰기
    4. MacBook Air 11" Early 2015 Trackpad Replacement: 9 단계, 이미지 3개 중 1개 MacBook Air 11" Early 2015 Trackpad Replacement: 9 단계, 이미지 3개 중 2개 MacBook Air 11" Early 2015 Trackpad Replacement: 9 단계, 이미지 3개 중 3개
      • Open the device about 10 degrees.
      • While holding the bottom of the trackpad, press up on the side of the trackpad closest to the logic board to free it from the upper case.
      • Remove the trackpad from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,884 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 51,304개를 작성함
4가이드 댓글
Hi. After my trackpad “click” started failing (it wouldn’t physically feel like a click when pressed and it wouldn’t respond unless you pushed hard and in certain areas) I went through the whole above replacement process with a trackpad I bought off of Amazon. The new trackpad has a better click on the right hand side but the left hand side is not working still.
Could it be that the new trackpad I got also doesn’t work? The reviews on Amazon indicated that the trackpads from this seller sometimes also failed.
Or is there another problem? I noticed there are two black rubber pads (made of a thin foam) that are between the base of the trackpad and the body of the macbook frame, and that in my computer they are worn/frayed. Could this be the problem?
If anyone has any knowledge about this, or advice about how to go about with this repair and trying different things, I would appreciate your help.
iamsyed1987 - 답글 공유
I’d love to know the answers to the above questions before I take mine apart!
Brittany Santos - 답글 공유
this was very easy thanks
ejri bejri - 답글 공유
Hola. Después de que el "clic" de mi trackpad empezara a fallar (no se sentía físicamente como un clic al presionarlo y no respondía a menos que presionaras con fuerza y en ciertas áreas), pasé por todo el proceso de reemplazo anterior con un trackpad que compré en Amazon. El nuevo trackpad tiene un mejor clic en el lado derecho, pero el lado izquierdo sigue sin funcionar.
¿Podría ser que el nuevo trackpad que compré tampoco funcione? Las reseñas en Amazon indicaban que los trackpads de este vendedor a veces también fallaban.
¿O hay otro problema? Noté que hay dos almohadillas de goma negras (hechas de una espuma delgada) que están entre la base del trackpad y el cuerpo del marco del Macbook, y que en mi computadora están desgastadas/deshilachadas. ¿Podría ser este el problema?
Si alguien tiene algún conocimiento sobre esto, o consejo sobre cómo llevar a cabo esta reparación y probar cosas diferentes, agradecería su ayuda.
E. Parra - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 83
전체 시간: 13,622
