주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
black screen when not charging boot loop when charging
so i dropped my iphone(SE) but it wasnt damaged visibly then it turned off i went to put it to charge and the apple logo popped up then went of this keeps happeneing then i took it out of charge and it became a black screen i searched up how to fix it but most of them is by using a home/lock button which i cant since my home/lock button is broken i need help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
As ur home button is broken has the phone been apart before??? Ie is the metal plate that holds the battery connector in place still in the phone, open it up and as a first thing to try check the battery is plugged in ok
댓글 달기
답변 1개
If you don't see a battery icon after you plug in your Iphone then the issue could be with your screen. As you have mentioned that you have dropped your Iphone so your screen might got affected with it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
iriscorreiap 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 57
