주요 콘텐츠로 건너뛰기
A collection of guides and support to help with washer repair.
Join on washing machine drum is sharp
Can some kind soul give us advice on how to cover the join on the washing machine drum which feels sharp and believe to be putting holes in my clothes?
Thank you
Update (07/27/2019)
Update (07/28/2019)
I agree, strongly believe it is a manufacturing issue. I spoke with Hotpoint support and advised to sign up to the Repair & Care to have an engineer come by.
Surely it is flaw with the drum as the join should not have lifted like that to create a shaving razor like effect. Have thoroughly rubbed a sock around the whole drum and the paddles again n case but nothing apart from the .
Have plonked a video up which you'll hear the catch of my finger.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Thanks both for your responses. It is Hotpoint washer dryer RD1176J and unfortunately has just gone out of warranty.
Will attach some pics
Hi, was the new drum fitted ok and snagging stopped?
댓글 달기
답변 2개
선택된 해법
Hi @dnarks ,
What is the make and model number of the washing machine?
How old is the machine? If it is still covered by the manufacturer’s warranty contact the manufacturer about the problem to get a warranty repair or replacement, so as to not void the warranty by trying to repair it yourself.
If it is no longer covered by the warranty post some close up pictures of the problem back here.
Here’s how to do this.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Hi @dnarks ,
If there are sharp edges on the seam, which are snagging the clothes, regardless of the warranty I would still contact Hotpoint and ask them regarding the problem as it may be a manufacturing problem which they should be interested in. Normal washing should not cause this to happen to the seam. It should be smooth.
It never hurts to ask.
Hi Jayeff
Thought I'd update to say Hotpoint came to fit a new drum yesterday (free of charge), however strangely engineer said the seams of their drums are manufactured this way but diagnostics showed mine had raised higher than usual. I can not wrap my head around it
Hi @dnarks ,
Thanks for the update.
I wonder if they've always done it this way or if this is a new way of doing it.
If it's a new way then they haven't tested it very well.
If it's the old way maybe they're using lesser quality materials, in an effort to safe money (or make more money) which don't have the same characteristics as before.
They might know but I don't think that they'll tell you.
Sorry for being so cynical.
Hopefully the new drum lasts a lot longer than the old one did.
Glad that you persevered with the manufacturer and ended up getting a good result for you
Good luck.
Hi @dnarks, did the new drum replacement go ok? Did the items stop getting
snagged?
Hi Deb
When the engineer came to fit on the border of the 2 year warranty, they showed me that even the new drum he was installing had the same sharp seam, and it is how it was designed. Quite shocked really.
Unfortunately can't remember if any snagging after as the washing machine completely broke down 6 months later! One of the feet had been knocked loose after the engineer put it back in the kitchen unit. Over the course of time/number of cycles it rattled more and broke the ballast brick inside. The inlet hose was also screwed back in at a wonk and didn't know we had a tiny leak for that time!
I had to take up a case with consumer rights and get my money back.
Will not purchase a Hotpoint or other related brands again. Bought a robust Hisense with no fancy features and it's been great
댓글 1개 더보기
댓글 달기
I would probably try smoothing it over with a product like this:
https://www.jbweld.com/collections/glass...
Assuming warranty is not in the picture.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Dan Parks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 38
전체 시간: 1,842
