주요 콘텐츠로 건너뛰기
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 질문 전체 보기
will freeze or start getting multiple green lines
I know that this is an old post, however if someone could help me with my tv issues that would be awesome. I have recently started having issues with my Vizio smart TV, where it will freeze or start getting multiple green lines that alternate on and off. The sound also goes when these appear. The only way I can get the tv to work is to power it off for a few minutes and then turn it back on. I think that it's important to know that I use the Amazon fire cube. Not sure if that's the issue or not, but even when the cube is not on and there is a black screen, it does this. So I'm not sure what to do at this point. If nothing can be done short paying a ton of money to fix it, then I will be forced to purchase a new one. If anyone can shed some knowledge on this, or point me in the right direction, It would be awesome.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Ok, will do. I'll let you know
댓글 달기
답변 1개
선택된 답변
coryconrad what exact model is it? Have you tried to disconnect all inputs and disconnect the power from the TV. Hold the power button down for about 30-60 sec. Then plug the power back in and connect one local video source (DVD BR or Game console) and check to see if that made a change. Do not try to stream etc. at this time. Also, try to disconnect from any network you may be on. Let us know what you get.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
coryconard 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 463
