Vibration motor does not work anymored after the baterry replacement
After the replacement of the battery the vibration motor stopped working.
좋은 질문 입니까?
좋은 질문 입니까?
Did you repair it yourself or did a shop do it for you?
The component is propably damaged and needs to be replaced,
If the shop repaired it for you they should replace the broken part.
해당 답변은 도움이 되었습니까?
I did it myself based on the instructions posted here. Normally I pay attention to instructions and until now I did not break running components when fixing other equipments.
What would help me is a how-to for the vibration motor in order to check if maybe its contacts got loose, as the vibration was working ok before changing the battery.
24 시간 전: 2
7일 전: 2
30일 전: 23
전체 시간: 566
Well unfortunately this happened to me as well just replaced battery then vibration stopped working. I looked at it and it was my fault when i was pulling up the main board i must have hit one of the components that power the vibra motor the components is so small about the size of a grain of salt and i am unable and not cordinated well enough to solder somthing that small so i will have to go without vibration but the location of the components on the board is so close to the edge it is my guess the same happened to yours
Eric 의
