주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
MacBook won’t switch on. Not sure what needs to be replaced?
Around beginning of May, I started having some problems with my MacBook. It’s been through a lot: I’ve dropped it a couple of times, let it sit in a hot car for several hours, been sat on, etc…but NEVER spilled anything on it. I’ve had it for almost 3 years now.
Problem: it started to get super slow and I still have 200 (of 256gb) of storage available on it. The fan started blowing really loudly, even when I’m not running any kind of software or program. It wouldn’t let me connect to WiFi. The charging said it was at 0%. I took it to the Apple store and they did a complete factory reset. Didn’t fix the problem. I let the battery run out on accident, charged it up, and it wouldn’t turn on. Did the SMC reset on it hundreds of times, with the charger plugged in and without. Nothing is working. I took it to the Apple store once again and the tech opened up my laptop and said he did something to the I/O board. He believes it’s an I/O board problem, but I’m not sure. Thinking it might be the logic board.
MacBook was running fine up until a few days ago. Was running a couple of pages on safari and Spotify and it randomly died & won’t turn back on.
I desperately need help. Starting college again soon and am looking for a quick but “cheap” solution. Please please please do not suggest an SMC reset. I have literally seen that everywhere and it does not work, in my case.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
After your visit to the Apple store, did it start or were you able to charge it?
댓글 달기
답변 2개
선택된 답변
Since it seems you've already replaced your battery and that problem persists even with battery disconnected there are fair chances you have a logic board issue at battery charging/Smc level. A faulty I/O board or connecting cable as well may give issues. You may try replacing them but be aware problem with DIY repairs is that you'll have to buy parts that may not solve your problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
A battery failure seems like the most likely problem. MacBooks do not turn on if the battery is damaged regardless of it being plugged in. You can order a Battery Fix Kit through iFixit (Linked Below) or have a repair shop replace it for you.
MacBook Air 13" (Late 2010-2017) Battery
If this helped please mark this as Solved.
MacBook Air 13" (Late 2010-2017) Battery 이미지
상품
$69.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi Sylvester,
Replaced the battery and it’s still having problems. It won’t turn on unless I unplug the battery and the fan is still running loudly. Any other suggestions?
댓글 달기
귀하의 답변을 추가하세요
hjlockerman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 87
