주요 콘텐츠로 건너뛰기
Repair guides and disassembly information for Wileyfox smartphones.
3 질문 전체 보기
removing battery on swift 2 +
the tear down is on you tube, but the battery removal from the face is done by using thin sheets of plastic sprayed with a liquid which is not identified in the video, it looks like water but may not be something electrically non-conductive
does anyone have a clue to this liquid please ?. thank you. Ben Littlewood.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
@beng0plo looks like its needed to loosen the adhesive strips. This iFixit Adhesive Remover an some of those Plastic Cards should work perfect for this.
Plastic Cards 이미지
상품
Plastic Cards
$2.99
iFixit Adhesive Remover 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Many thanks for your help. I have ordered the kit, and will advise you how I get on thanks again. Ben.
댓글 달기
귀하의 답변을 추가하세요
ben 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 452
