주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 질문 전체 보기
Help 4l60e constant shifting
97 chevy 5.7l vortec. Backfired through intake and blew pcv valve line off the intake. Drove it 20 miles not knowing it was off, abnormally high idle. Reconnected line now i get a back and forth 3rd to 4th gear shift. Rpm amd speedo jump around when this happens. Rebuilt trans 6000 miles ago. Tested all solenoids in tranny, all good. No Cel no stored codes. Any ideas? Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Also it doesnt always do this, sometimes it does perfect. Other times it does it right off the bat from first start up.
댓글 달기
답변 1개
가장 유용한 답변
Hey Lee.
Could be throttle position sensor issue (harness and/or wiring included). Throttle plate could have carbon buildup around it’s edges, as well. Also make sure vacuum lines and connections are sound.
Hope this might help.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
It did throw a tps code 1 time and 1 time only. Erased it and it hasnt came back. I will replace the tps and see what happens.
댓글 달기
귀하의 답변을 추가하세요
Lee stevens 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 52
