주요 콘텐츠로 건너뛰기
Club Car Golf Cart/클럽카 골프카트 브랜드의 이름을 따서 골프카 또는 클럽카라고 불리는 가스-구동 및 전기 골프 카트 지원.
494 질문 전체 보기
Lost power with charged batteries. Charger keeps you going on and off
While driving our golf cart, that had 3/4 power according to the indicator, it suddenly stopped and lost power. The indicator light went up to full charge but we had no power to move. The light stayed on full and occasionally dimmed. After pushing it home, we went to plug in the charger and the charger kept going on and off in fast succession. We unplugged it. Our batteries are due for changing but we never had this happen. It is still dead. What would cause this? Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
@slater64 any idea about year, make and model of your cart?
It is an ezgo freedom. I believe @ 2004-2008
댓글 달기
답변 2개
가장 유용한 답변
Hey Anthony.
Sounds like that battery’s had it. If you take it your local Napa, Advance, Pep Boys, etc., they will be able to test it and determine if there’s a dead cell, etc. If your battery can be recharged and then hold a charge then your charger isn’t working right or being operated correctly. Also, you may want to go over the relevant wiring on your cart and look for damage, loose or corroded connections, etc.
Good Luck.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Its the Battery Unit that is creating a problem,
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Anthony Merlo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 18
전체 시간: 401
