주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Trackpad not working but keyboard is
I have a 13” 2015 MacBook pro and the trackpad stopped working but the keyboard is working fine. Could it be the ribbon cable or the trackpad itselt?
Tried resetting all kinds of things but did not help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I would start with the cable as it can be damaged by grit and pressure from the bottom cover and battery MacBook Pro 13" Retina (Early 2015) Trackpad Cable
It’s also possible the trackpad damaged. I have had to replace a few as people tend to spray cleaner directly on the case and the cleaner can drip into the gap between the case and the trackpad and works its way into the sensor sandwich damaging it MacBook Pro 13" Retina (Early 2015) Trackpad.
MacBook Pro 13" Retina (Early 2015) Trackpad 이미지
상품
$54.99
MacBook Pro 13" Retina (Early 2015) Trackpad Cable 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Sensor sandwich! :)
@kadan - Take a look at the Magic Trackpad Teardown
And here's a better view of the sensor grid within it Sensor Array from the Magic Mouse. Unlike the mouse its flat and the connections are on the edge to the logic board.
댓글 달기
Before replacing the trackpad, make sure to check if it’s the SMC. Use this link.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
nugety 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 159
