주요 콘텐츠로 건너뛰기
A2115 / 2019 / 프로세서 3.0GHz 6코어 i5부터 최대 3.6GHz 8코어 i9까지. 2019년 3월 19일 출시.
131 질문 전체 보기
Is iMac 27 5k 2019 display adhesive strip are same as 2012-2017 model?
I’m looking for up-gradation kit of HDD to SSD on my 27’’ 5k iMac 2019 model. But I didn’t find out adhesive strip for the same. Is it same as 2012-2017 model adhesive strip?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Since the form factor has not changed since 2012 they are the same:
[연계 제품이 누락 또는 비활성화 됨: IF173-005]
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I’m very thankful for your reply. Is it goes to 27’’ 5k also?
Here is the 27" version [연계 제품이 누락 또는 비활성화 됨: IF174-005] and as far as I know the 2019 is no different than the 2017 strips.
But before you go down this path what is your reason you need to open the system? Such a new system should be serviced by Apple under its warranty program.
댓글 달기
I'm looking for those too, but read somewhere that the mic hole on newer iMac 27 is now on the lower side of the bezel and standard strips can cover it causing issues with the mic, don't know the exact details but I would like to know when the specific 2019 strips will be available in Europe, as they are in USA store.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
First I have used the same adhesive tapes across all of the 2012 ~ 2015 systems I've serviced.
Here's the iFixit part I would use: iMac 27" VHB Display Tape Kit - Apple Original (12-15), Apple P/N 076-1444
I have use a simple single hole paper punch to cut the needed location as needed for the 2017 & 2019 models a few times.
For the newer 2017 ~ 2020 I would use these tapes iMac 27" VHB Display Tape Kit - Apple Original (17-19), Apple P/N 076-00332 from TheBookYard in the UK.
댓글 달기
귀하의 답변을 추가하세요
Biswajeet Deka 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 603
