주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2265 질문 전체 보기
iPhone 7 Bootloop after Screen Replacement
Good day everyone,
yesterday i changed my iPhone 7 battery and replaced the cracked screen with a new one (both parts are from iFixit).
Then suddenly after i assembled all the parts back togetheri realized that i forgot to change the home button. But the device was running fine (except from a missing home button)
I repeated every step and transfered the old home button to the new screen.
This time when trying to boot, the device gets stuck inside a bootloop (apple logo will light up for about 15 seconds, then it goes out)
With the old screen the home button is functioning (i tested it)
Is there any solution to that, since i am curret´ntly using my device without one.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The iPhone 7/8 series have a very inconvenient bend on the Home Button flex. It’s really easy to tear the flex, either near the logic board connector or at the 90 degree bend before it sneaks underneath the LCD heat shield.
The other area that is easily damaged is the connector on the Home Button itself and the opposite connector on the short flex that runs underneath the heat shield.
The long and short of it is that there are multiple failure points. You will need to carefully inspect the Home Button and flex to see if there is any damage. Magnification here will help.  Look for tears to the flex or any physical signs of damage. You should also check the connector to insure none of the pins are damage or that there isn’t any debris.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Dan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 4
전체 시간: 93
