주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Phone is power cycling from apple log to off
Phone power cycles between off and apple log when plug in to charger and battery isn’t charging, try to DFU or Recovery mode phone but iTunes doesn’t acknowledge phone plug to PC. Should I try to use a charged battery to update software or is there something else that I can do ? I’m trying not to have to open the phone. Thanks in advance for your answer.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
boot looping is typically caused by three things in most cases. Battery, motherboard, software, from my experience in that order of how likely it is to be the problem (excluding certain device issues, such as iphone 7 home buttons being ripped). if you’ve already tried software, and it won’t install, you’ll end up having to open the device to try a known good battery. if that doesn’t work, you can try to frankenstein a charge port on the device (no need to fully install, just connect it) long enough to attempt the factory reflash.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you, the battery was the solution.
댓글 달기
귀하의 답변을 추가하세요
Rudy Camps 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 987
