주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z는 2013년에 출시된 안드로이드 기반 스마트폰입니다. 5인치 풀 HD 디스플레이를 탑재한 Xperia 제품군 중 가장 큰 스마트폰 중 하나입니다. 모델 번호는 C6603/C6602 등이 있습니다.
My phone doesn't boot (red led)
My phone started shutting down by itself many times during the day and also it became very hot.
So I decided to recover it through the Sony companion app. I did it many times because it never became usable but it turned black and now it doesn't show anything on the display and it isn't recognized anymore by Sony companion because it doesn't boot in download mode.
It can also be that it is dead in the middle of a recover done through Sony companion.
Now, if I connect it to the charger (or to the pc), it shows the red led for a while and it turns off. It seems that the phone “turns on internally” and then it turns off the red led.
If someone knows what is the problem and can help me, thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I would think it would be that your battery is faulty and you need it replaced
Your symptoms point to the battery been faulty
Before this accured was your battery draining very quickly If so another symptom that points to the battery
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you for your opinion
댓글 달기
답변을 추가하세요
ALBERTO PASQUALETTO 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 27
전체 시간: 338
