주요 콘텐츠로 건너뛰기
2018년 3월에 출시된 Apple iPad 6의 Wi-Fi 전용 버전입니다. 32GB 및 128GB 스토리지 옵션으로 제공됩니다. 9.7인치 레티나 디스플레이와 64비트 A10 퓨전 칩이 특징입니다.
151 질문 전체 보기
Fingerprint sensor not working correctly after screen replacement
Hey guys.
Just replaced my first one of these & I took extra special care when I got to the home button assembly.
I thought all was well but customer has just contacted me its not recognising finger prints.
Normally when home button is damaged you get Touch ID not working or failed message but I got none of that client face timed me to show me & they can go into Touch ID & passcode & add fingerprint they even get to the place finger on button part with the blank fingerprint but when they touch it on nothing happens normally you would get the red lines as it adds the fingerprint but they’re getting nothing.
Any ideas guys cheers?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi @inthebox
You can recommend a hard reset (holding the home and power button) and a software reset to fix the issue. Most likely this problem is caused by a small amount of damage to the home button cable.
If nothing is able to bring the Touch ID back, the device will need to be swapped out of warranty by Apple.
Best of luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kenny Leonard 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 84
