주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
How do you know if the optical disk drive is the same as the motherboa
Say you buy optical disk drive off of Amazon and when you get it has the daughterboard and everything but it’s not the same as the original daughterboard that was in the previous optical disk drive you had in the Xbox. How do you know if the daughterboard and motherboard are the same?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
You mark the drive board as original before changing out the laser. What I would do so desolder the motor cables and transfer the board only if it came as a whole drive.
Otherwise I would do a laser caddy transplant which involves removing the 4 screws that go on the rubber standoffs. To remove the whole laser assembly in one go.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You need to check the models of the drivee before buying one. There can be several OEM vendors supplying Xbox One disc drives and each vendor may have several models. Drives of different models obviously won’t have the same controller board and will not work.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
John 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 46
