주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
Why is my new MacBook Air battery not charging
The issue is with a MacBook Air, mid 2013.
The old battery was working, but cut out when it hit 40% or so. Bought a new battery, followed the directions carefully, but the battery isn’t charging. It says 0% and the battery icon won’t appear in the menu bar. Reset the SMC, opened it a second time and reset the connection and still nothing. As the one comment on this section noted, the connector needs to be folded a bit shorter so that the plugs meet, which I also discovered and did.
So why isn’t it charging?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
What are your Mag-Safe light telling you?
Please download and run Coconut Battery to give us a much better idea of what your battery is doing. Please post those results:
https://www.coconut-flavour.com/coconutb...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Daniel Siegel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 136
