주요 콘텐츠로 건너뛰기
2014년 10월에 출시되었습니다. 이 모델 SM-G530H/DV Samsung Galaxy Grand Prime은 화이트, 그레이, 또는 골드 케이스로 제공됩니다.
148 질문 전체 보기
How can I open my Samsung Galaxy to all South African networks?
Good afternoon
I would like to open my phone to be able to use Vodacom as now when I am inserting the vodacom sim it says “ Not Registered to Network”. Please help me as the Cell C network is I am currently using on the phone is giving me problems. I can not even perform hard reset or factory setting on the phone it totally does not respond to these commands. Please help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @vidoe ,
You need to “unlock” the phone from the Cell C network.
Either contact Cell C about an unlock code for your phone (and how much it may cost you to get the unlock code) or search online for Cell C South Africa unlock code to find companies that you can purchase the code from.
You will need to know the IMEI number of your phone. Dial *#06# from your phone to find the number in your phone.
Once it is unlocked you will be able to use any network that your phone is compatible with.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
My phone doesn't catch any network pleas help
@kinglionvundla
What is the make and model number of the phone?
Have you tried inserting a known working, network compatible same size SIM card into the phone and check if it detects networks OK?
Have you tried inserting the SIM card from your phone into another known working, same size SIM card, network compatible phone and checked if it worked there OK?
Basically swap SIM cards between two same network phones and check what works where.
Has the phone been dropped or gotten wet at all?
댓글 달기
Yes I want my phone to open all South Africa network
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vuyani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 178
