주요 콘텐츠로 건너뛰기
Samsung의 주력 휴대폰 Galaxy S8. 2017년 4월 출시.
304 질문 전체 보기
My phone keeps overheating and shutting off
So my galaxy s8 has started having this problem for a while maybe started 8 months ago. But if I have my brightness up too high and use it too long or play a graphically intensive game. The side with the power button will get extremely hot. This also happens if i’m in a hot environment or humid one and I even use the phone for too long. Then eventually it will shut off and if I turn it back on it will just shut back off so I have to wait maybe 15 minutes to turn it back on in order to use it. Other problems is it says its fast charging then switch to cable charging but charge at the same speed. Ive had the phone for two years now but I really don’t want to get a new one, so what should I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
May be u can factory reset and see if it helps.
A old used battery also is reason for heating. Just
Samsung Galaxy S8 Battery Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
When I used phone s8 plus after over heat phone was atomuticly switch off and coming some different sound how canning fix it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alex Salazar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 27
전체 시간: 2,208
