주요 콘텐츠로 건너뛰기
2018년 3월에 출시된 Apple iPad 6의 Wi-Fi 전용 버전입니다. 32GB 및 128GB 스토리지 옵션으로 제공됩니다. 9.7인치 레티나 디스플레이와 64비트 A10 퓨전 칩이 특징입니다.
20 질문 전체 보기
iPad 6 Home Button metal contact ripped
Hello, I successfully managed to remove a cracked screen from my ipad 6, but right at the end, the rectangular metal contact halfway down the home button assembly ripped. Can I access my ipad contents if I wire this damaged home button in? Or is it vital to replace it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
If you mean the Touch ID button flex cable broke(the little grey metal rectangle attached to the flex itself broke),it is repairable by a microsolderer. Other than that,you can maybe go to accessibility settings,assistive Touch. This allows a virtual home button function on screen.
The Touch ID function is tied by software to the logic board itself. So it is not replaceable unless apple will program a new one,which they would not do since you’ve opened the iPad…you can buy a home button replacement,but you will lose Touch ID function. Only physically pressing will work.
The only way to repair your Touch ID flex cable is to have someone that microsolderer tiny things fix it for you.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Anu Anand 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 947
