The Nikon D60 is a 10.2-megapixel Nikon F-mount digital single-lens reflex (DSLR) camera released in January 2008. The D60 is the successor to the entry-level Nikon D40x.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개
you might want to check the Owner Manual for "bright spots" and how to reset the camera to factory default settings before attempting to disassemble your unit. A copy of the manual in PDF format can be obtained at the following link:
@kenuto if everything checks out than it is possible that this is caused by dust etc on the CCD sensor. Let us know if you are up to replacing it. Cost is around $70USD
댓글 1개
https://www.camerauserguide.net/nikon-d6...
prop man 의
