oxygen sensor not communicatng
oxygen sensor not communicating code p140
좋은 질문 입니까?
Thoroughly examine the wiring harness to the oxygen sensor connector and then the wires to the sensor for cuts, breaks, abrasions, rubbing, etc. and fix where appropriate. Also examine inside the oxygen sensor connector to make sure the pins are there and are not dirty/corroded. If this does not fix the engine code or there are no issues with the wire harness, I would replace the oxygen sensor. I don’t think they are overly expensive for your vehicle. $20-$80 on rockauto.com.
해당 답변은 도움이 되었습니까?
thank you, i will try this, and let you know, thaks again
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 74
